About the Breitling Premier, it is not a new model, BLS published it in 2020, there are four models, each one is different in dial color, there are black, white, blue and green. The watch has a round case that is measured to be 42mm in diameter, case thickness is 12.5mm, for a chronograph automatic watch, it is very thin. The case is mirror-polished, with both sides being brushed. On solid case back, the engravings “BREITLING”, “1884” and Breitling Logo are polished, with sanded finish around them, which forms a high contrast.
The replica watch has a fully working chronograph function, check this black dial version, there are three subdials, each has a genuine feature and with silver grey dial color that is slightly contrast with the main black background. Minute-chronograph counter and hour-chronograph counter are positioned at 12 o’clock and 6 o’clock separately, when you push the buttons, the seconds-chronograph hand on the center with a red tip will start the chronograph. The watch has a stainless steel bracelet, while BLS factory also offers leather strap option for each model.
Replica Breitling Premier Blue
Replica Breitling Premier Green
Replica Breitling Premier White
Replica Breitling Premier BLS Factory
Replica Breitling Premier Black
Replica Breitling Premier Black Dial
Replica Breitling Premier Crown
Replica Breitling Premier Case
Replica Breitling Premier Case Back
Replica Breitling Premier Bracelet
Replica Breitling Premier Clasp
Source
Rate this post
Average rating 0 / 5. Vote count: 0
